It is currently Sun Aug 10, 2025 9:06 pm
PostPosted: Sun Feb 18, 2018 10:01 pm
I searched several older threads for this information but couldn’t find specifics on what I’m looking for.
I’m trying to determine if the tool will thickness the back of a headstock (scarf).
I’m wondering if it will cut into the rising angle to work that “would be volute area” down flat little by little or if it is made to do flat cuts.
B
PostPosted: Sun Feb 18, 2018 10:19 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Yes, you can use a Safety Planer for that.
PostPosted: Mon Feb 19, 2018 10:53 am
Last Name: Sollod
"if it will cut into the rising angle to work that “would be volute area” down flat little by little or if it is made to do flat cuts."
Not like this... A "smiley" volute is done with a sled on a stationary belt sander...
www.swiftcreekguitars.com
PostPosted: Mon Feb 19, 2018 11:20 am
it'll rough close to your volute but the tool is designed for flat surfaces. you'll have to detail out any contours in the usual ways.
PostPosted: Mon Feb 19, 2018 12:04 pm
First name: Freeman
Last Name: Keller
Here it is thicknessing the back of a broken headstock to receive a back reinforcement. As others have said, you'll need to do the volute and any curves some other way.
I guess you could say a broken head is an unintentional scarf joint
PostPosted: Mon Feb 19, 2018 1:48 pm
Well, you simply upgraded TO a scarf haha
Yea my question wasn’t clear I guess. If I simply wanted to flatten the area without a volute .... that’s what I was after.
Hey thanks for the responses
PostPosted: Mon Feb 19, 2018 2:01 pm
Yes. One can always take the back of the headstock material off with a safe-t-planer, take it close to the neck, then do the rest of the work with your favorite hand tools (e.g., file). But if it is a scarf, I sort of wonder why it wasn't at final dimension prior to glue-up - one of the nice parts about doing a scarf.
Andy
PostPosted: Mon Feb 19, 2018 4:03 pm
Andy
Andy, I’m pretty new at building so forgive if I don’t understand what’s going on exactly. Perhaps it is because I glue the scarf to the back of the angle ? Around here he 1st fret area, or well before, the thickness continually increases. The end of the headstock is at final thickness from planing top of it.
Again, not sure if I’m following .
PostPosted: Mon Feb 19, 2018 7:37 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
From what I understand, we used to use a Saf-T-Planer for thickness peg heads, but since I have been here, have used a simple bushing-guided jig with a straight 1/2" router bit to thickness and to rough out the neck transition and dart. The attached text and pictures are from a post by the boss on the process.
Quote:
This is V.02 of the peghead thicknessing jig; V.03 will address the x/y indexing of the template around the neck...currently fastened into jig through piloted tuner holes (or piloted holes in slotted headstock. The diamond volute is roughed in with 1/32" trimming allowance, while the neck transition for necks without is left large enough to accommodate several different transitions. A large Lexan base with bushing mount and a 1/2" downcut does the job, with feed direction as needed for smoothest cut. Obviously, if we did scarfs, we would just thickness prior to glue-up, but most of our necks are either one piece or joined with vertical glue joints, so stuck with a thicknessing task.
- Beth Brower
These users thanked the author Woodie G for the post: SnowManSnow (Mon Feb 19, 2018 8:22 pm)
PostPosted: Mon Feb 19, 2018 10:20 pm
First name: Freeman
Last Name: Keller
SnowManSnow wrote:
Andy
What Andy is saying goes back to earlier discussions we have had about scarf joints and neck carving. I've said several times to think about each step of the process to decide what order makes things the easiest. When you cut your head piece off before you turn it over and glue it on the neck, you might want to plane or saw it to its final thickness (minus the head plate). You've got a nice flat little piece of wood - you can tip it on its side on a band saw, run it thru a thickness sander or plane it down with you doohicky. (This is also a good time to make slots if its a slot head).
You can do it after its been glued on, but its a whole lot more awkward. Anyway, go back and reread some of your other neck threads and instead of just thinking about a single operation thing about the process.
If I had wanted a volute and backstrap like Steve's I would have left the head thicker, used the Safe-T-Planer and hand tools
